An attempt to delete an IPv4 blackhole route failed.
This system is running low on memory resources. The local or network configuration should be reduced to free up memory resources. ISIS should be disabled and renabled in order to re-synchronize the local routing table with its peers once memory resources are freed.
Error
IPv4 route delete request for blackhole route failed with error %rc%
| Name | Type |
| rc | sInt |
